actuator hvac 01 coup dual zone
Old Jul 27, 2007 | 12:18 PM
extanker's Avatar
Default actuator hvac 01 coup dual zone
has anyone r+r ed the pass. side actuator on an 01 coup? can i go through the radio or glove compartment or pull top of dash? tried batt reset,code b0446. the driverside is very cold ,pass side very hot.tanks
Old Jul 27, 2007 | 07:29 PM
Dave01's Avatar
Default RE: actuator hvac 01 coup dual zone
You need a recharge of refrigerant. The hot side - cold side symptoms are classic conditions of a partially charged refrigerant system.
Dave
Old Jul 29, 2007 | 09:52 AM
extanker's Avatar
high and low side psi,s are good.the code is for the door not moving
Old Aug 2, 2007 | 08:01 PM
moscooter's Avatar
I've recently went thru and (still have), the same basic problem. Two weeks ago, my system went hot and I knew it was out of freon. I had it checked, and they re-charged it with freon and (dye) and said drive it for a couple of weeks, and then we will check for the dye showing where it is leaking.
Did that, and it was from an O-ring on the firewall which they replaced and re-charged the system. Then, all of a sudden they tell me and the scanner (as well as my own check via the DTC's the nextday), the passenger side ducts are blowing hot while the center and drivers side blow cold.
The (labor chargealone), to get to andcheck out that door that is (not closing/opening) properly is over 4 plus hours......!!! My solution is that (whomever) is ridingwith me is gonna be warm while I enjoy cool air causeI'm not investing the total cost to solve this one.........
P.S. Understand that these models do NOT HAVE HEATER CONTROL VALVES as most did in the past. This means that the (door) in question slides closed to block off heat from the heater core for a/c operation and opens (partially) to "blend" warmer air as necessary or opens all the way to allow full heat from the heater core. While the actual problem could be a bad (Body Control module), and bad (HVAC module),I'm told it's most likely a bad plastic gear that drives the(door) open and closed.
Old Aug 2, 2007 | 09:43 PM
extanker's Avatar
ORIGINAL: moscooter
i was hoping for a short cut [through the radio] but it looks like pulling the dash is the way. oh boy. i,m gonna try one more fix.a snake of some type to go through the pass. vent and see if i can nudge the door
Old Mar 14, 2020 | 09:35 AM
DKvet's Avatar
Try recalibrating the air blend actuator. That may clear the door from sticking.
Old Mar 16, 2020 | 01:21 AM
kruser
Jun 18, 2006 02:39 AM
dcoxworld
Jun 8, 2006 04:31 PM
vicutif1
May 31, 2006 06:55 PM
jd2000
Dec 11, 2005 04:15 AM
everman31
Oct 10, 2005 11:40 PM
