74 IS NOW RUNNING GREAT!!!!!
Old Jul 12, 2007 | 12:13 PM
SCHOON's Avatar
Default 74 IS NOW RUNNING GREAT!!!!!
Hi All,
First I would like to thank everyone for their input.
Thought you might like to know what it took to get my 74 running the way it should.
Turns out both of my floats were set to high.
After setting them correctly the car ran better but still had some bucking under a load.
Sprayed carb cleaner and added fuel additve to clean out system, no help.
Noticed that inline clear fuel filter had a black spot of something floating around in it and where the rubber fuel line attaches to the bottom of the filter the clamp was missing,the hose was ready to pop off.
This would have been a real serious problem on the road.
Gas would have been sprayed at 4-5 psi all over my hot block.
I replaced the filter and rubber fuel lines and all clamps.
Problem now solved, car never ran this good.
I wonder if the rubber gas line being loose and ready to pop off had something to do with the bucking or was it just the filter and the float adjustmets.
Anyway, live and learn.
Schoon
Old Jul 12, 2007 | 06:16 PM
Default RE: 74 IS NOW RUNNING GREAT!!!!!
[sm=icon_rock.gif]Glad to hear it's all better. Thanks for the feed back, in my case, it helps to verify if I wason the right track or not. Partially yes, but I see others were hittin' the mark too.
Thank you!
Old Jul 12, 2007 | 08:58 PM
wrwalke's Avatar
It is possible that the loose fuel line caused a Venturi effect (sucking air into the flowing fuel) instead of squirting it out. This would definitely screw things up, just a thought.
bill.
Old Jul 12, 2007 | 09:35 PM
Bazackly what I was thinking Bill.
Schoon- great to hear that you solved the problem and thanks for letting us know the out come. Cheers
Old Jul 12, 2007 | 09:57 PM
pg's Avatar
Hi Schoon, glad to hear you fixed itand for free. Life is good, PG
Old Jul 12, 2007 | 11:58 PM
Great that you got it fixed. Now you also know why GM uses steel fuel lines on the pressure side of the pump.
Old Jul 24, 2007 | 08:22 PM
ax's Avatar
ax
AHHHHHH.......Nothing better than a no cost fix. Great to hear it's running good now!
white88
Sep 1, 2006 06:08 PM
gorichb
Aug 21, 2006 11:50 PM
romar
Aug 7, 2006 02:07 PM
WHIPSrx7
Aug 2, 2006 06:16 PM
Apr 11, 2006 10:33 PM
