"Barn finds" they're still out there!
Old Apr 7, 2024 | 10:09 PM
74HARLEY's Avatar
Default "Barn finds" they're still out there!
Never stop looking my friends, follow up on leads, look behind houses when you drive around new areas. I did a quick follow up on a lead that sounded impossible. Now I'm negotiating with the current owner to aquire a '71 454 4sp. Convertible with both tops. 140k , been off the road since 1985. Engine is missing. Tranny isn't. I'll keep you updated as things proceed.
Old Apr 8, 2024 | 10:56 AM
Good luck.
Old May 1, 2024 | 10:56 PM
74HARLEY's Avatar
Well, I did it! I am now the proud owner of a car that has been off the road since 1985. I'll keep this updated until it's back on the road.
Old May 2, 2024 | 12:22 AM
Are you going to try to put it back stock? Do you have any history on the car?
Old May 2, 2024 | 09:39 AM
74HARLEY's Avatar
Yes, I m going try and keep it basically stock. It's a base 365hp. 454, I will probably just run an aftermarket manifold and carb. I got the original exhaust manifolds so they're going back in. I did get the original carb, I'm not really a Q jet fan but we'll see.
Old May 2, 2024 | 10:35 AM
IIRC, that's a LS-6. Since it doesn't have the engine, I assume you are getting that information from the tag on the console. I know a lot of people don't like Q-jets but they are easy to work on and have a lot of tuning capability. I grew to really appreciate Q-jets after working on my friend's '66 427/425 Holley for several years. The good things about Holley carburetors is they have a lot of adjustments. The bad thing about Holleys is they have a lot of adjustments. You almost need a dyno to really get the full capability out of them.
Old May 2, 2024 | 03:51 PM
74HARLEY's Avatar
Here she is on the way home!
Old May 2, 2024 | 04:13 PM
A good thing about this generation of Corvettes is that you can get just about every part for them at a fairly reasonable price usually. Big block roadsters are usually a good investment also.
Old May 4, 2024 | 08:53 PM
74HARLEY's Avatar
She is resting comfortably in the shop now.
Old May 12, 2024 | 09:52 PM
74HARLEY's Avatar
Spent a little time in the shop cleaning it up today.
Engine arrives tomorrow!
