brake master cylinder
Old Dec 16, 2013 | 05:05 PM
orangevette's Avatar
Default brake master cylinder
I need to replace the master cylinder on my 74 vette. The cylinder is pitted and bypassing. Do I need to bleed the brakes when I change the master cylinder or can I just replace it and go. Any help is greatly appreciated.
Old Dec 16, 2013 | 09:52 PM
ken82's Avatar
yeah u def have to bleed. needs to be bench bled then bleed at the wheels using the correct sequence
Old Dec 16, 2013 | 10:32 PM
ken82's Avatar
they can be a pain to get all the air out
Old Dec 17, 2013 | 10:09 AM
Pressure bleeding is the best way. Having a helper push on the brake pedal is the second best way. Vacuum bleeding is, in my estimation, not a good way because it tends to suck air past the seals and you never get all the air out of the system.
deacon312
Oct 22, 2008 12:09 PM
jdeatsch
Jun 24, 2007 10:10 PM
kcclark66204
Jun 5, 2007 04:00 PM
57halfton
Sep 5, 2006 02:49 AM
79vette
Dec 7, 2005 01:51 PM
