C4 brake master cylinder
Old Sep 30, 2008 | 10:56 AM
deacon312's Avatar
Default C4 brake master cylinder
Glad to be a part of the forum now, guys and gals. Just signed on and have a quick question regarding a brake issue that recently developed in my '88 coupe. Unfortunately,I'm in the middle of a move right now and don't have access tothe equip and tools I need to work on it myself, so I'm at the mercy ofa local mechanic.
Occasionally when I come to a stop, the brake pedal goes almost all the way to the floor. It doesn't happen all the time. Pumping the brakesrestores the pressure andtightens up the pedal. Thebrakelight will sometimes come on in conjunction withthe pedal softness. I know my pads and rotors are fine,the fluid level istopped off (and clean), I don't have any unusual noise or alignment issues.
I've been told thatthis is a sign that my brake master cylinderis bad, and that the sealsbetween the resevoirs has developed a leak that is causing thefluid to shift from one chamber to another resulting in increased pedal travel.My questions are (1) does this sound like a good diagnosis of the problem and (2) is there any solution other than replacing the entire master cylinder (ie, is it possible to repair only the seal)?
Any help with this is appreciated!
Old Oct 3, 2008 | 02:00 PM
Curious George's Avatar
Default RE: C4 brake master cylinder
My questions are "(1) does this sound like a good diagnosis of the problem and"
CG - Yes.
CG - Most times master cylinders are not rebuilt, but replaced. If you could find the seals only it would be possible, but it is far too convenient to replace the unit with a new one.
Old Oct 3, 2008 | 05:23 PM
Wedge's Avatar
IMHO... its just easier to replace and core the old one. A lot goes into a rebuild... they hone the piston bore, replace all the parts... check for stripped threads... just easier to replace it I guess. And... whats your time worth? It eats up a bit of time rebuilding one... at least a sixer too...
[align=left] [/align]
Old Oct 22, 2008 | 12:09 PM
Krytdrgn's Avatar
I doubt the master cylinder would be too much to replace and it is aneasy install. But it definitely sounds like that is your issue.
orangevette
Dec 17, 2013 10:09 AM
jdeatsch
Jun 24, 2007 10:10 PM
kcclark66204
Jun 5, 2007 04:00 PM
57halfton
Sep 5, 2006 02:49 AM
79vette
Dec 7, 2005 01:51 PM
