brakes
Old 07-04-2013, 08:17 AM
orangevette's Avatar
Unhappy brakes
On my 1974 vette the brake pedal goes to the floor and barely stops the car, the brake light stays on. The master cylinder is full of fluid. There are no leaks on the floor. What could be wrong? Any help is greatly appreciated. Thanks
Old 07-05-2013, 09:25 AM
No symptoms are usually caused by a bad master cylinder. Do you have power brakes?
Old 07-06-2013, 11:22 AM
yes, I have power brakes
Old 07-06-2013, 11:28 AM
Can you pump the brakes up by repeatedly pressing on the pedal?
Old 07-06-2013, 03:35 PM
I can pump the brake pedal but it barely comes up and stops the car. It does not come up all of the way to where it should be.
Old 07-06-2013, 07:25 PM
When you pump them up, does the pedal still go to the floor? If so, then I'm pretty sure it's the master cylinder then.
Old 07-06-2013, 07:57 PM
Yes, the pedal goes all the way down to the floor. Do you think the master cylinder needs to be rebuilt or replaced? Is it possible that a seal or something is bad?
Old 07-06-2013, 08:03 PM
Well if the bore is not pitted w/ rust you might be able to rebuild if you can find a kit.
Old 07-07-2013, 07:32 AM
I'll check to see if there is any pitting and if not kits are available from MidAmerica Motorworks. Thank you for your help. I will let you know what the results are when I fix the problem. Thanks again!
Old 07-07-2013, 10:27 AM
How are your brake calipers?
Quick Reply: brakes
