Bubba under dash
Old Sep 24, 2007 | 11:32 PM
Default Bubba under dash
While I'm savin' up scratch for the new rad and fans, I thought I'd trace bubba's wiring under the dash. I can't evendescribethe mess I found. []
My question is...
It looks like I can access the wiring and replace all the wiring harnesses with the main guage cluster removed. Am I right, or do I need to remove the entire dash? Thought I'd ask before I tear into it.
Old Sep 25, 2007 | 12:04 AM
Default RE: Bubba under dash
I think you'll have to remove both the speedo/tach cluster and the center gauge cluster to get access to everything.
Old Sep 25, 2007 | 03:42 AM
78buckshot's Avatar
Dave, you should be able to get to the majority of the terminations in the harness with both of the gage panels out, also remove the glove box and you'll have a little more wiring in that area. The center console contains wiring for the power windows, auto trans shift indicator light and neutral switch, parking brake switch. Unless Bubba used bolt cutters on the main harness or the rodents have done their handywork you should have enough access to make repairs. Pulling the dash panel is a real nightmare and hard to do without damage to the crunchy vinyl, I had mine completely gutted to make repairs to the dash itself but don't take it out if your not ready to put $500 into a new panel. See ya.
Old Sep 25, 2007 | 07:43 AM
Another question....
Will the new harnesses plug into the fuse block, or is it an intrigal part of a harness?
Oh ya, Bubba used 12ga. stranded, from an extention cord, to run two wires from the bats pos terminal. As I understand, the main juice distribution comes from the starter harness, right?
Old Sep 25, 2007 | 08:06 AM
Phill's Avatar
I believe the fuse box is included in the new dash harness, atleast it is in my 79.
Old Sep 25, 2007 | 11:40 AM
I did a friend's '66 a few years ago and the fuse block was part of the new harness. The only problem we had was the sheer size of the cable made it so stiff that it was hard to route like the original.
Kevin98c5
Dec 4, 2008 04:52 AM
ZR1clone
Mar 23, 2008 09:33 PM
Rickcusaf
Nov 19, 2007 07:01 PM
Rickcusaf
Sep 13, 2007 09:58 PM
jeepin45
Aug 11, 2005 12:57 PM
