A/C and Air pump performance hits
Old Jul 9, 2007 | 07:34 AM
  #21
Default RE: A/C and Air pump performance hits
I won't venture a guess here. I'll take some time and look it up later today. Hope I can find an answer for ya.
Old Jul 9, 2007 | 06:32 PM
  #22
To maintain good idle and drivability under all conditions, other input signals are used to modify the ECM output signal. These input signals are supplied by the Engine Temperature Sensor, Vacuum Control Switches, Throttle Position Switch, Distributor, Manifold Absolute Pressure Sensor, and Barometer Pressure Sensor.
Does this answer your question?
There is a whole chapter on engine emission controls in the manual I have.
Old Jul 9, 2007 | 08:07 PM
  #23
78buckshot's Avatar
Wow Dave, thanks. I think it might answer the question about the effect that the A.I.R. has on the ECM, no mention of it in the description.
Old Jul 9, 2007 | 08:28 PM
  #24
Well there's a lot more, just tryin' to be more to the point at hand.
I really hate this stuff. Used ta be ya set the points, timing, plug gap, and tweeked the carb a little. Oh how I yern for the good ol' days.
Old Jul 9, 2007 | 08:34 PM
  #25
78buckshot's Avatar
Your in the process of bringin' the good ol' days back to life with the Starship, somehow I'm thinkin' it ain't gonna' have EGR,AIR,EFE, catalytic,ECM, ect.
Old Jul 9, 2007 | 09:14 PM
  #26
Have what?!?!? Wash your mouth out with Penzoil! [:'(]
Old Jul 9, 2007 | 09:23 PM
  #27
78buckshot's Avatar
I thought that might wake you up, Can't I use something a little more palatable, like Quaker State or Valvoline.
Old Jul 9, 2007 | 10:10 PM
  #28
I use Castol GTX 10-30.
Old Jul 9, 2007 | 10:11 PM
  #29
I use Castrol GTX 10-30.
Old Jul 16, 2007 | 10:05 PM
  #30
Batmobile's Avatar
This weekend I conformed that the air pump is blowing into the unfiltered side of the air cleaner. Therefore, if anyone believes this is abnormal, speak up!
The exhaust has been modified so that the tube that formerly went to the catalytic converter was eliminated and crimped shut. I don't know if this is going to throw off the air system and possibly affect my air/fuel ratio since there is more oxygen blowing into the exhaust manifold. Any thoughts?
