C3 steering locked up
Old May 3, 2018 | 12:34 PM
Default C3 steering locked up
Just came across a barn find '80 C3. The owner has the right keys but the ignition switch won't turn to unlock the steering.
Can the steering lock and ignition switch be accessed by removing the steering wheel and assembly?
Old May 5, 2018 | 12:27 AM
It could on my '73.
Old May 10, 2018 | 12:03 PM
Thanks, we will dig into it this weekend.
Old May 10, 2018 | 12:08 PM
As you probably already know, the actual switch is mounted on the steering column down close to the firewall. It's actuated by a rod that runs up the steering column to the ignition lock.
Old May 15, 2018 | 12:40 PM
No, I did not know that. Never been into the column before. THANKS!
Got sidetracked last weekend, hope to dig into it soon.
Old May 15, 2018 | 04:08 PM
There's a special tool that will depress the lock plate so that you can remove the wire retaining ring. While I've done it without the tool a couple of times, I found it a lot easier with the tool. I think I may have got it at JC Whitney years ago.
Old May 16, 2018 | 12:05 PM
JC comes through again. LOL
Amazing the odd tools you can find there.
Thanks.
