C3 steering locked up
Just came across a barn find '80 C3. The owner has the right keys but the ignition switch won't turn to unlock the steering.
Can the steering lock and ignition switch be accessed by removing the steering wheel and assembly?
There's a special tool that will depress the lock plate so that you can remove the wire retaining ring. While I've done it without the tool a couple of times, I found it a lot easier with the tool. I think I may have got it at JC Whitney years ago.
