Climate Control Help
Old Jun 14, 2010 | 01:52 PM
MikeC3's Avatar
Default Climate Control Help
Hi All. Thanks for your continued help as I put this car back together. My 73 has a hissing/leak at the climate control ***** when I rotate up above the Heater setting (Defrost and Heater do not have leak). Any of the Vent, A/C and Off settings have the leak. It gets louder as I scroll up to Off. I found the actuator that's under the passenger side dash and pulled off the hose to feel suction. And, when I scroll off of A/C, I can see the actuator move (it's not pretty, but it seems to be working). I replaced the climate control valve in the center dash since that's where the leak is sounding, but that didn't make a difference. I'm guessing that an actuator is bad. But, which one? And, where is it?
Also, when having a key in the ignition and turning it On (not starting the car), should the blower be operating at all when the top blower setting is set to Off?
Thanks!
doyle
Jul 11, 2007 07:21 AM
mcat1212
Dec 27, 2006 08:46 PM
acossey
Jul 9, 2006 03:06 AM
FINALLYGOTIT
Apr 12, 2006 05:14 PM
Billromans
Oct 29, 2005 02:36 AM
