climate control display is very very dim.
Old Apr 8, 2006 | 03:38 AM
acossey's Avatar
Default climate control display is very very dim.
I have purchased a used 2001 with the dual climate control. The display is very dim when you first start the car. After about 15 min. it becomes a little more visable. I have turned up the panel lights as high as they go. Am I missing somthing? Also the #2 and #4 radio preset buttons are not lit at night. Please help!! thanks
Old Apr 8, 2006 | 04:10 AM
acossey's Avatar
Default RE: climate control display is very very dim.
Never mind I found the answer about 9 pages back. Sounds like a new head unit.
Old Apr 10, 2006 | 10:03 PM
predator1082's Avatar
where did you find the answer... my climate control takes about 30 seconds to fade in after i start the car...
Old Apr 11, 2006 | 09:37 PM
acossey's Avatar
on this forum about 8 pages back. the bottom line was that there is a grounding issue in the head unit. The only fix is to open it up and attemt tpo resolder or replace the unit. The guy with the answer gives a link to a supplier of the head units and says they are about 250.00
Old Apr 12, 2006 | 05:13 PM
PAY2PLAY's Avatar
Here is a link to the post Acossey is speaking of: Click Here
Old Jul 8, 2006 | 09:44 PM
TAILWAG's Avatar
actually I had found a link before that dealt with some pieces in the circuit that needed soldered again...I guess a lot of people were having that issue. I am having the issue but I am not brave enough to tear into it....
Old Jul 8, 2006 | 10:43 PM
knob's Avatar
Actuallly, if you look on ebay under corvette climate control, there are several shops that will swap you a refurbished unit with a 5 year warranty for under $100. I swapped mine and its exactly like new.
Old Jul 9, 2006 | 03:06 AM
TAILWAG's Avatar
I was referring to this:
http://forums.corvetteforum.com/show...227&page=2&pp=
tangoloco
Oct 13, 2010 10:00 AM
pewter2000
Dec 19, 2008 12:19 AM
Genocide
Dec 28, 2006 05:52 AM
mcat1212
Dec 27, 2006 08:46 PM
Billromans
Oct 29, 2005 02:36 AM
