Dash lights went out
Old May 4, 2009 | 12:15 AM
Rickcusaf's Avatar
Default Dash lights went out
Hiya, was driving home and the dash lights went out when I turned on the radio. It's dark out so I have not fiddled with anything yet, but I'm wondering what it could be.
They didn't flicker at all they simply went out when I turned on the radio.
Plans tomorrow are to check the fuses and ground (Do I need to remove the dash housing for the ground?), but other than that I'm not really sure what to check.
As always any help is appreciated.
Old May 4, 2009 | 02:31 PM
SCHOON's Avatar
I would say your radio has a short.
The problem started when you turned it on.
If your dash light and radio are on the same fuse that's it then, bad radio wiring.
Sometimes you can have a wire uder your radio that has been rubbing for years and finally wore off the plastic coating.
Good luck,
Schoon
Old May 4, 2009 | 08:59 PM
Rickcusaf's Avatar
Got lucky. =) Was just a blown fuse. Checked all the wiring just to make sure anyways and everything seems good.
Old May 5, 2009 | 09:38 PM
Do the lites still work w/ the radio on?
Old May 7, 2009 | 03:03 PM
SCHOON's Avatar
Good point, what made the fuse blow in the first place.
Last year I had a fuse circuit blow time after time.
Turned out to be a door light switch.
Old May 30, 2009 | 08:18 PM
What year is your Corvette?
IVAN1215
Technical Diagram Help
Sep 24, 2007 01:50 PM
ddc1932
Jun 2, 2007 01:12 AM
rjensen
May 24, 2007 05:11 PM
Vette93Racr18
May 1, 2006 01:40 PM
