differential yokes (side)
Old Apr 15, 2007 | 02:41 AM
Fuzzy74's Avatar
Default differential yokes (side)
I am having problems installing the side yokes in my differential, I am not sure how to install the yoke and snap ring into the differential. Its a tight fit and I am stuck can someone help?
Old Apr 15, 2007 | 08:10 AM
78buckshot's Avatar
Default RE: differential yokes (side)
Hi Fuzzy, did you take the yoke's out yourself or are you re-assembling someone else's teardown? The splined end may need a little attention with a small file to remove the burr from the splines, make sure the snap-ring groove will accept the new ring before you slide the yoke in. Your right, there's not much room to work inside the diff. case but with small long-nose pliars and small screwdrivers I was able to rotate the snap-ring to a point where I could snap it on by pushing straight in on it, good luck.
Old Apr 15, 2007 | 04:14 PM
Fuzzy74's Avatar
everything is new, so there shouldnt be too many problems as far as old sutff goes.
Old Apr 15, 2007 | 04:49 PM
78buckshot's Avatar
Well then, unless you've got the wrong parts it should go together quite well, just takes a little patience.
GRAMPS ZO6
Corvette C5 Z06
Dec 9, 2020 08:34 PM
payton34
Jul 4, 2006 10:58 AM
vetdriver
Corvette C5 Z06
May 7, 2006 06:44 PM
TEC1
Sep 3, 2005 04:09 PM
c44me
Jul 1, 2005 08:21 AM
