differential yokes (side)
Hi Fuzzy, did you take the yoke's out yourself or are you re-assembling someone else's teardown? The splined end may need a little attention with a small file to remove the burr from the splines, make sure the snap-ring groove will accept the new ring before you slide the yoke in. Your right, there's not much room to work inside the diff. case but with small long-nose pliars and small screwdrivers I was able to rotate the snap-ring to a point where I could snap it on by pushing straight in on it, good luck.
1966, corvette, diameter, diff, differental, differential, differrinial, install, installation, ring, side, snap, stuck, tight, yoke, yokes, yolks
