Engine "chugging"
Old Sep 3, 2007 | 06:21 PM
cyclic hardover's Avatar
Default Engine "chugging"
I would like to ask an engine question here that has been bugging me for a few years and the possible cause. I won't blame the moderator for shutting it off here. First off the vette is fine. My "other vehicle is a 92ford 5.0 fuel injection 4x4. Has 180,000 miles and maintenance is done regularly. Thing is for several years, around town engine sounds fine and strong. I have had various engine work done like alternators, water pump, wires plugs . Bottom side was done with new bearings and seals. Thing is when ever I go out of town a few miles and start going up a hill, I get this chugging/bucking type feel going up the hill. If I step on it into passing gear, engine races up and I'm fine. Does not have to be a steep hill either. Its like a combination of a miss/chugg/who knows.
Any thoughts?
Old Sep 3, 2007 | 06:25 PM
D.T.'s Avatar
Default RE: Engine "chugging"
[sm=dontgetit.gif]
Ignition timing not right at low rpm's? Vacuum leaks?
Old Sep 3, 2007 | 06:37 PM
Sounds like it is staying in overdrive and running on torque. What speeds are we talking about? My '87 auto does that if I'm under 35mph. I just press down on the accelerator and let it shift like you said.
Old Sep 3, 2007 | 07:19 PM
starts around 40ish when i go up an incline, does not have to be steep either.
Old Sep 3, 2007 | 07:20 PM
ORIGINAL: blueshark
Exactly, is this normal?
Old Sep 3, 2007 | 07:21 PM
SCHOON's Avatar
Sounds like a gearing thing. My 74Vet will do that and I give it the gas and away the problem goes.
Cause is the 3:36 rear and a Healthy cam.
Old Sep 3, 2007 | 09:20 PM
ORIGINAL: cyclic hardover
Yup, that's normal. A combination of low rpms and high gear. You are low on your power curve.
Old Sep 3, 2007 | 09:24 PM
Like Starship said, I believe it is normal when the rpms are low to a certain extent and the tranny is still in OD. If the incline were a little steeper it will down shift on it's own Like mine does. I don't think it is anything to worry about but you can check with your local tranny shop to be sure.
CH. By the way...That's a great looking vette.
Old Sep 5, 2007 | 10:43 AM
Thanks, just basic black and some decent wheels and tires.
Old Sep 5, 2007 | 06:34 PM
Black...The ultimate color for any vette! My C3 is soon to be.
