Engine Code
Old Jan 24, 2018 | 08:15 AM
bmessina@bbins.com's Avatar
Default Engine Code
I have a 1970 454 with AT and without TI - the casting number is correct but this is what I am finding for the engine code: CEO70868
This makes no sense to me as I can't find anything regarding this sequence. These numbers are on the block below the passenger side head above timing chain cover.
Old Jan 26, 2018 | 08:33 PM
Really need to know what is stamped on the block in front of the psgr side head. The last portion of that stamping should be the last of the VIN. If that's what you have, then it looks like it might be a replacement engine.
Here's all I could find: BIG BLOCK ENGINE CODES
