Fiberglass hood-burst hose causing bleeding of hot antifreeze
Old Oct 15, 2020 | 11:33 AM
Terry J Hays's Avatar
Default Fiberglass hood-burst hose causing bleeding of hot antifreeze
First Timer: Hose burst forcing hot anti-freeze fluid into the fiberglass hood. Result- 1' x 2' area on top of hood showing bubbles
all the time and "weeping" when driven and engine/sun is hot.
Have been told the only remedy is to form a tub, fill with water and use turbo heater to boil the water until all of the anti-freeze
contaminants are expelled.
Is this the only way to attack the problem with buying a new aftermarket hood? THANKS!
Old Oct 17, 2020 | 01:39 AM
I seriously doubt there's really any way that you can can ever completely remove the contaminates but you could check with a body shop that paints Corvettes.
farout
Dec 4, 2011 12:59 AM
DrJ
Mar 6, 2009 04:32 PM
supersport
Sep 17, 2007 08:00 PM
majorbob
Jan 25, 2006 11:47 PM
pg0099
Jul 7, 2005 11:05 PM
