HELP HELP HELP
Old May 18, 2007 | 02:08 PM
74vetguy's Avatar
Default HELP HELP HELP
NEED HELP I cant get the fan shroud out from behind upper a frame bolts. Needs to be remove replace rad. HELPPPPPPPPP[:@][>:]
Old May 18, 2007 | 02:50 PM
jrs 2.0's Avatar
Default RE: HELP HELP HELP
i don't know much about your problem, but for the future a book like rebuilding the small block chevy are great they have alot of info
Old May 18, 2007 | 04:20 PM
78buckshot's Avatar
Hey 74, if it's like my 78 you have to pull the radiator up past the shroud and get it out of way before the shroud can come out, I had my boy help to reduce the chance of damage.
Old May 18, 2007 | 06:23 PM
I pulled the rad, and then the shroud came out pretty easy. Pulled the fan and pully too.
