help suspensions project
Old Apr 7, 2008 | 09:29 PM
  #21
Default RE: help suspensions project
Aldo, I don't believe you'll be able to get any kind of grinder in the recessed area where the T-arm bolt is plus you'll probably have to cut both ends off.
Leafs from springs can be rearched. You'll just have to see if anyone does that where you are.
Great deal on your insurance.
Old Apr 7, 2008 | 11:38 PM
  #22
pg's Avatar
When I removed the front trailing arm bolts I taped up half a hack saw blade with duck tape and went at it after I got a few of the shims out, took a while but it worked. That is one tight spot to work in. A sawzall will make it a lot easier and quicker.
I used poly bushings and new ss shims. PG.
Old Apr 9, 2008 | 12:41 PM
  #23
Glad you got 'em out. Before I got a Sawzall, I did as you did with the taped hacksaw blade. Not much fun but got it done.
carid
Apr 7, 2015 08:20 AM
twitch2k6
Sep 17, 2006 07:39 PM
twitch2k6
Aug 19, 2006 12:53 PM
norm
Feb 1, 2006 03:10 AM
dcsbh
Nov 2, 2005 11:54 PM
