Intake manifold height LS-4 vs. ZZ454 crate engine
Hello everyone, I'm new to the forum, just purchased my first C3, a bright yellow 74 coupe with numbers matching 454/auto, from Autoexotica in St. Louis, maybe some of you saw the car on eBay recently, it was there. Anyway, I am considering pulling out the original engine and setting it aside and dropping in a ZZ454 crate motor. I would like to keep the factory air cleaner and cowl induction setup but am wondering if the dual plane intake in the ZZ454 will be taller than my LS-4 intake causing clearance problems witht he hood. Thanks for any advice.
Paul in Memphis/Users/test2/Desktop/14.jpg
Paul,
Go to your local speed shop and take a measurement of the intake you plan to use, then compare
the measurement with the intake on your car. Lay a flat bar across the intakes and measure to the carb base. This should give you some idea. Sometimes the speed shop can give you the dimentions.
gilsl82
Jun 27, 2007 07:20 AM
mrs_torchd
Oct 25, 2005 01:31 PM
