lifting a c3 101
Old Jan 26, 2007 | 10:16 AM
Phill's Avatar
Default lifting a c3 101
kind of a silly question, but what is the proper way to lift a 79 c3 w/ttops.reason im asking is cause two buddies told me these cars have to be lifted with doors and hood open. i checked the factory repair manual and its says nothing of the sort. also did a search on here but found nothing. where doing the starter and trans filter tomorrow ata toyotadealership i work atso i thought id ask just in case.
Old Jan 26, 2007 | 10:50 AM
wrwalke's Avatar
Default RE: lifting a c3 101
Always safer to lift a fibreglass car with the doors and hood loose. I've had mine on the lift a dozen times with the doors and hood closed though, and haven't had a problem yet. As long as the frame and body mounts are strong, and you lift from good lift points with solid contact to the frame, you won't have any problems.
bill.
Old Jan 27, 2007 | 02:09 AM
Phill's Avatar
thanks for the reply. ended up doing the work to her today. turned the caron andoff a few times checked the the trans fluid everything looked great. went toleave and it wouldnt turn on.power to all gauge and acc. no power to the starter. where going to look at it again tomorrow.
Viscount
Sep 13, 2013 01:55 PM
extanker
Jun 4, 2007 11:41 PM
Dave01
Dec 15, 2006 05:42 PM
jmrazz
Oct 6, 2005 11:25 AM
Jbson@butogeek
Aug 6, 2005 03:27 PM
