No heat
Old Mar 17, 2008 | 08:49 PM
  #11
Default RE: No heat
ORIGINAL: pg
Hi 73shark, look on the left side under "Table Of Contents" "Upgrading The Fan", is that what your looking for? PG.
Well I thought it would be but seems to be just a R & R how-to. Unless you think that the later blower motor/fan was a stouter unit.
I think I might have seen it on the other forum w/o the "s". [] Have to sneek over and take a peek.
Old Mar 17, 2008 | 10:01 PM
  #12
pg's Avatar
Default RE: No heat
My A/C works borderline OK, it seems like a longer fan with a better blade angle would help, but its quite a bear of a replacement since so much stuff has to be removed to do it. I might try it someday but it's not very high on the list of things to do. Maybe if the heater, or should I say when the heater core gives out than I'll try that upgrade. PG.
Old Mar 18, 2008 | 11:21 AM
  #13
DeeVeeEight's Avatar
Banned
Default RE: No heat
ORIGINAL: pg
My A/C was the same way until I replaced the heater control valve, it seems that the heat was always "on" just a little bit. The new control valve cured that.
[sm=icon_cheers.gif]
nautques4ever
Feb 10, 2007 10:13 PM
EC15
May 7, 2006 02:00 PM
faleure
Nov 26, 2005 03:46 PM
faleure
Oct 11, 2005 03:10 PM
BBPREPRO
Jun 29, 2005 07:31 PM
