Pilot Bearing on 350 Engine
Old Jul 7, 2008 | 01:53 PM
pfrey12's Avatar
Default Pilot Bearing on 350 Engine
I am replacing my clutch and they recommend to replace the pilot bearing at the same time. Does anyone know an easy way to replace this bearing? It looks like it might have been pressed in.
Old Jul 7, 2008 | 05:28 PM
78buckshot's Avatar
Default RE: Pilot Bearing on 350 Engine
Hi pfey12, welcome to the site if that hasn't already been extended to you. The last time I read something about pilot bushing removal it went like this, find a shaft, rod, or bolt, that is a close fit in the bushing, fill the bushing with heavy grease and pound the shaft into the bushing cavity, the hydraulic pressure is supposed to force the bushing out. If that won't do the trick, I would use a slide hammer and rig up something to grab the back of the bushing.
Old Jul 7, 2008 | 06:30 PM
I've used the grease method, works really well.Once it didn't, and a puller/slide hammerwasn't handy, I used a die-grinder and cut the sucka into thirds. Tapped the pieces out with a screw driver and a small hammer.
Have fun!
Old Jul 7, 2008 | 09:43 PM
Do you have a Harbor Freight store close by. They sell a "pilot baring puller for pretty cheap or you might try going to Auto Zone or advanced auto parts or any nationsl chain auto parts store. Most of them loan/rent tools. It is a simple task with the right tool. takes about 1-2 minutes and no cutting or banging and ne chance of damage.
here's one....
http://www.harborfreight.com/cpi/cta...temnumber=4876
Old Jul 28, 2008 | 07:47 PM
pfrey12's Avatar
Thanks for the info. I do have one of these stores near me.
chevyvette
Oct 6, 2013 11:41 PM
Ttoptom
Feb 17, 2008 01:31 PM
proto69
Nov 9, 2006 03:18 PM
jetmech09
May 18, 2006 02:05 AM
