Probs with newly bought 72 roadster
Old Feb 1, 2018 | 05:55 PM
Mark Thornton's Avatar
Default Probs with newly bought 72 roadster
Help I just bought a 72 roadster 350 small block auto trans.. With Factory AC However some idiot cut of the evap. lines flush with the box and removed the condenser and AC pump and Rec /dryer My Question can I use a Evap from A Chevy car instead of a Corvette will it fit? Also I cannot get the key to turn to off pos to remove it is an automatic car.. Noting seems to work Need some advice here Thanks in advance Mark
Old Feb 2, 2018 | 05:56 PM
Trying to get a passenger car unit to fit would probably be an exercise in futility. Your best bet would be to look into getting a Vintage Air system to put in it. I took a system out of a wrecked 73 Corvette and put it into my 73 and it was not easy but doable.
I believe on the automatic cars there is a cable that connects to the steering column that will allow the key to be removed when the transmission is put into Park. Check into that and see if the cable is both there and connected and possibly adjusted properly.
Old Feb 2, 2018 | 06:55 PM
I will probably go Vintage air on the compressor but go New on the evap coil .. I will ck that cable.. Thanks for the info.. Now thinking of going LS3 with 6 speed conversion
