View Poll Results: A poll
aluminum radiator with stock fan
0%
aluminum radiator with dual eletric fans
33.33%
go back with stock and spend money else where on the car
66.67%
Voters: 6. You may not vote on this poll
radiator set up what do u think ???
Old Jul 20, 2007 | 07:41 AM
spanky01's Avatar
Default radiator set up what do u think ???
i have to replace my radiator and have a few options!!
Old Jul 20, 2007 | 08:19 AM
Default RE: radiator set up what do u think ???
I propose another option.
IMO, go with the alum rad and use a single elec fan.
I was conciderin' the same options, in one of my posts,when it was explained to me that the single fan would cover a greater surface area. I haven't gotten to that point in my mods, but I'm goin' to go with the single fan.
Old Jul 28, 2007 | 08:05 PM
Texas Jim's Avatar
I'm a guy who likes the original stuff unless engine mods are made that call for (in this situation) better cooling. But I have to admit, when beating my "Vette along the highway in Texas on a 100 degree plus day, the temp gauge goes up alittle higher than I like for a small block Chevy. Seems to me that the front of the car doesn't get as much air as it wants. I'd hate to remove the front bottom cowl and rubber edging as that's the only thing thatdirects the air flow to the radiator. I do know that my cooling system is in perfect shape. I've had many many small blocks from 283s to 350s and the first thing I do is install a 160 degree thermostat as anything in the 190s gives you little time to shut down once the cooling system malfunctions (ie: thermostat sticks) and the needle skyrockets. I think you should go with the new finned water tank and electric fan. Whatever cools the best as that makes a happy and therefore healthy engine. Good luck and let us know the outcome.
Old Jul 28, 2007 | 09:04 PM
Def do not remove the bottom cowl, be sure that all of your front air foils are firmly in place.
Marty73
Dec 31, 2006 01:30 AM
Raupleminze454
Oct 19, 2006 07:05 PM
wrwalke
Sep 11, 2006 02:12 PM
Bagpipingjake
Aug 21, 2006 11:20 PM
stang2x
Nov 15, 2005 10:38 PM
