Rear brake rotors
Old May 3, 2014 | 05:55 PM
dcerjr's Avatar
Default Rear brake rotors
Is it possible that the rotors on my 1971 vette are rivited to the rear hubs. Any info would be greatly apprieciated.
Old May 3, 2014 | 05:58 PM
dcerjr's Avatar
If they are best way to remove
Old May 3, 2014 | 06:01 PM
dcerjr's Avatar
rear rotor only. front i have removed
Old May 4, 2014 | 07:59 PM
If the rivets have never been drilled out, then yes the rears are riveted to the hubs. If they are still riveted, be sure to mark the rotor location wrt hub because the rotors are turned after riveted to the hub when the car was built. If you put them back on differently, there will probably be excessive runout which will pump the caliper pistons and will suck air into the caliper and then you'll be w/o brakes.
MoMoney
Jan 19, 2008 02:38 AM
MoMoney
Jan 8, 2008 01:28 PM
95trplblkandtan
Apr 25, 2007 08:35 PM
vette001
Dec 22, 2006 11:51 AM
Mudwrestler
Jun 11, 2006 11:00 PM
