Shark t-tops rattle
Old Aug 21, 2008 | 09:39 AM
vetguy's Avatar
Default Shark t-tops rattle
Any suggestions on how to stop70's t-tops from rattling? Adjusting the two rubber stops on the handles used to remove the tops has done nothing? The weatherstripping is not in bad shape. Not sure about the small plastic inserts where the tabs of the t-tops go in each side of the center brace. Could they be the problem? Anyone else found a solution?
Old Aug 21, 2008 | 08:07 PM
Default RE: Shark t-tops rattle
After latching them goomers down, do a little pushin and pullin here and there. Once you find the loose spot you can decern the prob. Check your hardware to make sure your latches are tight. If the center is loose, then you are on the right track with the inserts in the center brace.
Old Aug 21, 2008 | 10:21 PM
There are also shims associated w/ the center bar tabs.
Old Aug 23, 2008 | 11:54 AM
SCHOON's Avatar
I had the same problem with my 74.
After playing ariound with the ajustments I finally worked out the noise.
gigabyte
Jun 26, 2009 03:41 PM
blknblu68
May 6, 2007 01:41 AM
e36mpwr
Oct 10, 2005 11:20 PM
e36mpwr
Oct 2, 2005 04:57 PM
e36mpwr
