Side pipes on 78 big block
Old Oct 18, 2012 | 08:56 AM
corvettesam's Avatar
Default Side pipes on 78 big block
I am putting a big block 454 with Merlin heads in my 78 vette. The sales rep at Ecklers said the headers and pipes were made for stock engines. what headers and side pipes can i buy that will fit? also, what size pipes and what coating is preferable for street use? thanks
Old Oct 18, 2012 | 04:43 PM
SCHOON's Avatar
I just put Hooker SS side pipes on my 74.
No worry about rust and they look great.
You might need to get a shop to fabricate a special pair of headers for you.
Old Oct 19, 2012 | 01:52 PM
Is the exhaust port configuration different on the Merlin heads?
Old Oct 19, 2012 | 03:20 PM
Not that i can tell, a rep at summit racing said the hooker header hok2222-1hkr would fit so i think i will go with that.
Old Oct 19, 2012 | 03:40 PM
You might give Hooker a call. I'd definitely investigate the "why" before I went custom.
Old Oct 22, 2012 | 05:27 PM
I called hooker via holley and they said it would fit if it did not have angled plugs, which it doesn't. Thanks for posts, by the way, very confusing reading on big block coil springs. I think I need 550 lb springs, any thoughts?
Old Oct 23, 2012 | 07:41 PM
Check w/ Vette Brakes on the springs. 550 does sound about right for a BBC.
Glad the headers will work for you. Assume you're getting the "nest of snakes" style.
Old Oct 29, 2012 | 08:57 AM
yes, will complete engine installation this weekend, with luck.
AmericanCarCraft
Aug 2, 2013 10:46 PM
Curt
Jan 29, 2010 02:44 PM
hester
Dec 6, 2007 12:11 PM
57halfton
Mar 23, 2006 07:41 PM
buck
Jul 3, 2005 09:45 AM
