Stuck hood solution
Old Nov 13, 2007 | 01:00 PM
Default Stuck hood solution
Stumbled across this in one of my Corvette mags: http://www.mamotorworks.com/corvette-1-0-3852.html
Didn't do a search on this forum so may have been here before.
Old Nov 13, 2007 | 06:05 PM
Default RE: Stuck hood solution
That is way cool. Thanks!
Old Nov 13, 2007 | 06:08 PM
batesy80's Avatar
Thats good to know, I infact spray my cables with PB Blasterhere and there to prevent this, but I always have that feeling that some day it will happen. thanks for the info shark, Scott
Old Nov 13, 2007 | 08:34 PM
Your welcome. It's one of those things that after you see it you wonder why you didn't think of it. I've toyed with how to do this ever since I got mine cuz I could see the problem. Even put a second crossover cable on as a backup.
Old Nov 13, 2007 | 09:42 PM
pg's Avatar
I've had trouble with my hood ever since I took the left male side off to clean it.
Put it back on, closed the hood and the hood stayed closed.
After much shaking it opened up, readjusted the part, closed the hood and again it stayed closed.
More shaking and it opened again.
Took the part off and put it away.
So now I have to pull up the left side of the hood and reach under and pull the cross cable then the right side pops up.
I'm tempted to pull the right side off and get hood pins.
Or, just remove both pin, doesn't seem like the hood would ever pop up!
What do you think? PG.
Old Nov 14, 2007 | 05:19 PM
Flying Low's Avatar
Thanks for sharing! Every time I pop the hood I think of what could go wrong. And you are right you can never lube a 36 year old too much.
Old Nov 14, 2007 | 05:47 PM
batesy80's Avatar
lube a 36 year old!! we are talking about corvettes right? hehehe
Old Nov 14, 2007 | 09:11 PM
ORIGINAL: pg
First if you don't have any latch or pins, nothing to stop people from screwing with your engine.
Now back to the problem. I spent a half day adjusting a friend's '66 hood and never got it to where it wouldn't pop the right side open when you hit a bump. He and another guy worked on it for a couple of hours and viola, got it right. Moral: keep after it and you'll get it.
Old Nov 15, 2007 | 10:39 PM
pg's Avatar
Hi 73shark, I'll leave the hood alone for now, I'm afraid that if I adjust it again it won't open again. And I ain't do'ing that again. PG.
PinnacleWax
Dec 27, 2013 12:22 PM
goldie
Jun 26, 2009 10:15 AM
fille9
Sep 17, 2006 06:50 PM
steve47714
May 18, 2006 02:29 AM
dave n
Jul 5, 2005 12:22 PM
