Mytee Big BOSS Solution Sprayer now available at PinnacleWax.com
We Now Carry the Mytee Big BOSS Rechargeable Solution Sprayer on PinnacleWax.com
Portable battery-powered solution sprayer provides ultimate car cleaning versatility
Say goodbye to the power cord and electrical outlet and say hello to the Mytee Big BOSS Rechargeable Solution Sprayer! This rugged, 5-gallon electric solution sprayer is designed for continuous heavy-duty use in all mobile detailing situations. With an on-board battery and universal intellicharger, the Mytee Big BOSS Rechargeable Solution Sprayer is the most advanced battery-powered solution sprayer available!
The Mytee Big BOSS Rechargeable Solution Sprayer should be the first item on your list if you plan on starting your own mobile detailing business. Featuring a 5-gallon lift-off-tank, a 15 foot coiled solution hose and easy-grip storage basket plus the ability to clean with or without chemicals, the Mytee Big BOSS Rechargeable Solution Sprayer is one of the most versatile detailing tools available.
The Mytee Big BOSS Rechargeable Solution Sprayer includes a Sidekick spray bottle as a standard feature. This bottle allows you to store additional chemicals on board. Switching to chemical cleaning is as easy as attaching a quick connect. With the extended lance spray jet, you can even clean carpet and upholstery with ease!
One of the drawbacks of being a mobile detailer is the inability to rinse wheels, tires, and engine bays after using all purpose cleaners and degreasers. While hand pumps do the trick, they don’t provide enough pressure to blast the cleaner out of cracks and crevices. The Mytee Big BOSS Rechargeable Solution Sprayer is the answer you’ve been looking for! Now you can clean wheels, tires and engine bays with confidence!
Warranty Limited lifetime warranty
Body Roto-molded polyethylene
Tank 5 gallon
Pump Diaphragm
PSI 60
GPM 1.2
Battery 10 AMP hour
Volts 12
Spray per Charge 60 gallons
Charger On-board
Jet 8006
Wheels 8"
Casters 3" dual front swivel
Product Weight 43 lbs
Product Dimension 20 1/2" x 13" x 37"
Wipe Off
That Was Too Easy! Took me less than 10 minutes to wash the car. I love this wash method :icon_headbang:
GET YOUR Mytee Big BOSS Rechargeable Solution Sprayer at PinnacleWax.com
Tank 5 gallon
Pump Diaphragm
PSI 60
GPM 1.2
Battery 10 AMP hour
Volts 12
Charger On-board
Jet 8006
Wheels 8"
Wipe Off
