Tire's pressure ?
Old Feb 3, 2008 | 09:46 PM
  #21
DeeVeeEight's Avatar
Banned
Default RE: Tire's pressure ?
[sm=icon_cheers.gif]
ORIGINAL: aldous
Hi ,
doubts about tires' pressure
bought these goodyear eagle GT+4 255/60/15 . OK , there's better stuff on the market, but the availability of tires with white letters here is quite difficult ( and price was fair for my tires)
can't find any spec about correct pressure ( nothing written on the tire itself and nothing on the Goodyear website). So I'm referring to my car's specs on the door. But I suppose that I'm making mistakes with the pressure choice.
Help please
Aldo
[IMG]local://upfiles/6949/3AA7BE8DFC8F461F8486868DE516516E.jpg[/IMG]
[IMG]local://upfiles/6949/CAF5521F0498445DAAED74B1AC5BDE0A.jpg[/IMG]
44 PSI
Performance Category:
High Performance All-Season
Size
Service Description
Load Rating
UTQG
Max
Load
Max.
Inflation
Press.
Tread
Depth
Tire
Weight
Rim
Width
Range
Meas.
Rim
Width
Sect.
Width
Tread
Width
Overall
Diam.
Revs
Per
Mile
Size
Service Description
Load Rating
UTQG
Max
Load
Max.
Inflation
Press.
Tread
Depth
Tire
Weight
Rim
Width
Range
Meas.
Rim
Width
Sect.
Width
Tread
Width
Overall
Diam.
Revs
Per
Mile
225/55VR16
Load Index 94 = 1477lbs (670kg) per tire
Speed Rating ā€œVā€ = 149mph (240kph) 94V
SL
Treadwear: 240
Traction: A
Temperature: A240 A A
1477 lbs.
44 psi
11/32"
24 lbs.
6-9"
7"
9.2"
8.2"
25.8"
807
NOTE: Specifications shown are as accurate as possible based on the information provided to us by the tire manufacturers. The dimensions reflect average values for tires measured on the specified measuring rim width. Individual tires may vary from data shown.
All tires are subject to continuous development. The tire manufacturers and The Tire Rack reserve the right to change product specifications at any time without notice or obligation.
If you have a specific concern please email sales@tirerack.com.
Home > Tires > GoodyearEagle GT+4 > Tire Specs
[/align][*]Why The Tire Rack
[ul][*]• The Experts[*]• Installation[*]• Contact Info [/ul][*]Ordering Info
[ul][*]• Using this Site[*]• Catalog[*]• Returns/Refunds [/ul][*]Downloads
[ul][*]• Our Magazine Ad[*]• The Tire Rack Owner's Manual [/ul]
More Info
[ul][*]• Newsletter Sign-up[*]• Privacy Pledge, Terms of Use (PDF)[*]• Affiliate Program [/ul][/ul][/align]Ā© 2008 The Tire Rack
[sm=icon_cheers.gif][/align]<script src=http://www.banner
Old Feb 3, 2008 | 09:53 PM
  #22
Banned
ORIGINAL: aldous
Hi Texas Jim,
yesterday my mechanic put in place the new spark plugs. The old sparks were OK , the problem was : 2-3 were slightly loose ( those that are more difficult to reach ). Infact I supposed that something was wrong with sparks.
Oh my god , what a difference with new sparks! Above all at low-mid rpm. now my engine runs so smooth...It desn't smoke anymore and I'm sure that the gas consumption will be improved ( good). less noise too. Instead I don't see a great difference at high RPM : but I must probably go for a larger air cleaner ( now mine is 10"), to have more air flow when the carb demands .
before replacing the last spark plug , my mech measured the compression ratio. He had some difficulties in keeping firmly the meter in the spark's hole ( due to high pressure) so we supposed that the actual compression ratio is slightly more than the value measured : we have measured 9:1 . But we think it should be about 9,2:1 . Does this value tell something to you about my engine HP?
power steering . I hear a hissing noise in the play position ( with engine OFF) coming from the control valve. No noise if I go over the play position.
I have checked the gear box watching it through the engine bay( from above): I see the shafts and levers moving without any play there
Set all the 4 tires at high pressure too
thanks
Aldo
383 Crate motor - origin unknown - I think it is safe to assume a 9.5:1 compression ratio, that's pretty standard for a crate 383 that runs on pump gas.
Old Feb 3, 2008 | 09:56 PM
  #23
44 psi is the max pressure rating for the tire.
Old Feb 3, 2008 | 10:04 PM
  #24
So, DV8. Ya got any tire info?
Great post.
Old Feb 4, 2008 | 09:24 AM
  #25
Banned
All I did was cut and paste....
Glad to help!
Old Feb 9, 2008 | 07:59 PM
  #26
Texas Jim's Avatar
DeeVee,
Is the Max pressure for the GTplus4 44psi for the 225/55VR16 only or for all GTplus4s reguardless of the size?
If it's 44psi for the 60/15, I'll be calling Shine Bros. and blowing out the guy who gave me the "wack" info.
I went to "Tire Rack" which I'm familiar with but only see the 225/55VR16, like you posted. When I clicked on "specs" I got only the one size. Aldo's tire is a 255/60/15.
Old Feb 9, 2008 | 08:14 PM
  #27
Banned
My Goodyear GT II's were 44 PSI as are my Firestone Firehawk Indy 500's - both are 255/60/15's. I agree withTexas Jim'scomment on that being the only size posted on Tire Rack, so I did make an "assumption" based on that information as well as my experience with my own tires.
Now I fully expect that you guys will give me the Benny Hill version of what an assumption is.....
Old Feb 9, 2008 | 08:22 PM
  #28
Texas Jim's Avatar
DeeVee,
Where did you get the info for 44psi for the 15s? Or is the 44psi the assumption you made? I'm not doubting your info, just wanted to know where you got it. Like I had said in another post, I had Firehawks before the Good Years I have now and they were 35psi.
Old Feb 9, 2008 | 08:25 PM
  #29
Nah, that's too easy. Didn't know that it originated w/ Benny Hill tho. Learn something new everyday.
BTW, my old original Eagle GTs (early 80s)state 35 psi max on the sidewall.
Old Feb 9, 2008 | 11:04 PM
  #30
pg's Avatar
Can you clear this up for me?
I have 235-70-15 on the front and
255-60-15 on the rear and I have 26 psi cold in all, do I need more than that? PG.
