Tire's pressure ?
Old Feb 10, 2008 | 09:36 PM
  #31
Default RE: Tire's pressure ?
Depends on several things. Even tire wear, comfort, lower friction, handling. My door sticker says 20 psi for the original GR70-15s. I ran about 28-30 in them and got even wear and decent mpg. For autoX, I ran low 40s to keep the tread on the ground.
Old Feb 11, 2008 | 09:09 AM
  #32
Phill's Avatar
I usually run about 32-34 psi. what i find funny isthe door sticker says to run 20/26 for fuel economy.
Old Feb 11, 2008 | 09:40 AM
  #33
aldous's Avatar
Hi Phill,
my sticker says 30 psi frontand 35 psi rearfor fuel economy. you have a 79 Corvette. what does your door sticker says?
after all the infos on this topic, I'm running my tires at 34-35psi. 44 psi as DV8 says seems so high to me ...
I have seen anywaythat there'snothing sure about our Corvette tires' pressure... so please everybody continue on this topic , so we can reach "akindtruth" about.
To have the proper pressure is a matter of safety too
Old Feb 11, 2008 | 10:18 AM
  #34
Phill's Avatar
I'll have to check tonight, but it should be the same. i was noting the optional pressure on your sticker 20/26 seems low by todays standards.
Old Feb 11, 2008 | 02:03 PM
  #35
Texas Jim's Avatar
After reading all the replies under this topic, and all the different tire pressures on door stickers, I'm wondering why all the different answers. Would the different pressures on the doors have anything to do with where the vehicle is being shipped to, geographical location? That doesn't make perfect sense to me either seeing where everyone is from and considering the psi they've posted. And Aldo w/ two different pressuresfor the front and back, WTF?
I run a tire at max psi as I buy the tire for whatthe tire isabout. I want it to do what it's supposed to if I decide to beat on it, so I want the pressure to be up. I've run race compound tires at a low psi in the past for better "off the line" traction knowing that it's not great for the side walls. I like a hard tire, psi-wise, as theyfeel better all around. I don't like over-inflating a tire as it's hard on the belts and I don't want to slip a belt long before the tire is worn out, even if it didn't prematurely wear the tire in the center. Those Firehawks rode hard and I did run them alittle soft, but not less than 30psi.
If running a tire very soft or very hard didn't kill the tire prematurely, then I see no reason why a person shouldn't do what they want.
Still don't know what the reason for so many different door sticker pressures.
How about we make a post to list; 1. the year of your 'Vette 2. the door sticker tire psi recommendation 3. the original shipping destination of your 'Vette.
Maybe we can figure outwhat the differences in psi info on the door has todo with; local, year, ora combination of both, or something else entirely different. ***Unless someone has this thing figured out or no one gives a crap. LOL I, for one, would like to know.
bobvet
Jan 19, 2007 02:59 PM
2001c5
Nov 29, 2006 08:42 PM
rjensen
Jun 26, 2006 09:17 PM
sorlowski
Dec 4, 2005 11:01 AM
bRKrbcing
Jun 29, 2005 03:25 AM
