Videos of the Vette with and without my Super40s
Old Jul 9, 2008 | 04:55 PM
DryCreamer's Avatar
Default Videos of the Vette with and without my Super40s
Here's a video of my Vette right after we cut the mufflers off:
http://www.youtube.com/watch?v=MjRDwNhEA_s
Here is with the new Flowmaster Super 40s:
http://www.youtube.com/watch?v=fx88xTDW-NM
Specs
Summit Iron heads, 8.4:1 compression, 230 duration @ .050 int/ext | 110 deg lob. sep.| .488 lift int/exh
single exhaust thats kinda why its raspy when you rev it with my mufflers
this is before I spun the rod bearing, I just got my block back from the machine shop, so I should be able to start putting my engine together, everything is the same cept I got flattop pistonss so it should be 9.4:1 compression!! hopefully I will get duals next, it is in the budget!!
Old Jul 9, 2008 | 09:01 PM
Default RE: Videos of the Vette with and without my Super40s
What's your head combustion chamber volume? The reason I ask is the L-82 w/ flat tops and double valve reliefs has a CR of 9:1 with a 72 cc head.
Old Jul 10, 2008 | 11:50 PM
DryCreamer's Avatar
I have 67cc heads
stock CR was 8:1, with the stock 76cc heads
the stock pistons have a massive 18cc dish, but remember, I spun a rod bearing, so my new engine, which I start assembling this weekend, will have the flat-tops and a .022" head gasket which should put me just over 9:1
I was VERY disappointed when I took the heads off and saw those pistons
