vin number / whats it worth?
Old Apr 16, 2008 | 04:20 PM
husker's Avatar
Default vin number / whats it worth?
I am new to the corvette deal, I have vin number for a car I am looking to purchase. Can I use this to determine what the car originally came with (engine, trans, body color, etc.) or do I need the build sheet.
What would a 1970 corvette coupe be worth, good mechanical condition, needs paint, not original engine? The car is currently 350 ci with auto trans, the owner states that it originally was a 4spd car (clutch pedal and linkage still in car) but does not know what engine it came with. The car runs and drives good just needs to be repainted, and some tlc. I think I can buy it for about 9K is it worth it?
Thanks[/align]
Old Apr 16, 2008 | 06:59 PM
Default RE: vin number / whats it worth?
Welcome to the site. Give a look here. Cheers
http://www.vettefacts.com/Default.aspx
Old Apr 16, 2008 | 11:33 PM
1974corvetteowner's Avatar
Hey Husker if you are having troube with trying to figure out the vin (i doubt you will) you can post the vin and we would be willing to help you out
BTWGreat site BlueShark...I dont think i have even seen that one before
Old Apr 17, 2008 | 07:07 AM
husker's Avatar
Thanks for the link. The vin number is 194370S410990. From what I can see all that can be determined from the vin is body style, location of build, that it has a V8, and that it is in fact a corvette.
Is there any way to tell what engine/trans/etc. that came with this car originally without a build sheet? Is there any way to obtain a build sheet using the vin number? What is the "tank sheet" and where on the tank is it located? Is it on all cars?
Thanks
Old Apr 17, 2008 | 07:53 AM
Phill's Avatar
try this site mortec.com this will show you where to look to see if its the original engine and heads. usually the last portion of the vin is stamped on. the vin on the trans i believe is on the right side about half way back, but im not sure. do a search im sure youll find plenty of info on it.
Old Apr 17, 2008 | 02:20 PM
Unfortunately there is no way to tell what engine came in the car without know the origonal engine serial number.
There are a total of5 engine options
Standard ZQ3 350ci 300hp around 7000 for production
L46 350ci 350hp 4,910 produced
LT1 350ci 370hp 1,278 produced
LS5 454ci 390hp 4,473 produced
LS7 454ci 465hp unknow production numbers
As for the transmission there were 2 manual transmissions offered in 1970 the are Muncie M21 and the M22 and after looking at production numbers there were 4,383 car with M21 transmissions and only 25 with the M22 so your car most likely came with the M21 transmission
fishdos
Nov 9, 2007 11:42 PM
CC/AT
Feb 24, 2007 09:14 PM
blueshark
Dec 21, 2006 02:27 AM
TealC4
Nov 15, 2006 12:06 AM
1974corvetteowner
Dec 28, 2005 01:51 PM
