wheel studs
Old Mar 10, 2006 | 01:55 AM
383Stroker's Avatar
Default wheel studs
How hard is it to change wheel studs on a c3? i broke 3 off on the passanger side, rear. if anyone could point me to a write up or tell me in a brief discription, i would be grateful! thanks
Old Mar 10, 2006 | 02:26 PM
Clayton's Avatar
Default RE: wheel studs
If I am not mistaken, the rear on a C3 (you didn't specify year) has drum brakes so you should be able to pull the brake drum off and knock out the broken ones with a punch and hammer. Then insert the new ones from the inside of the drum. Never done it on a corvette but have on other GM vehicles of that era. I think I'm right. Someone tell me if I am wrong. If they are disc brakes, I am at a loss because I haven't done the job on disc.
Old Mar 11, 2006 | 09:45 PM
383Stroker's Avatar
mine has disc brakes... it's a 76
Old Mar 12, 2006 | 03:17 AM
Only problem is to make sure you have room on the back side of the hub to drive the old ones out. Insert the new ones in holes from inside and use a standard steel lug nut turned around backwards with a washer behind it. Screw the lug on each stud and here's where its tricky. It sure helps to have an air compressor with a 1/2 " impact to buzz it right on the back side til the shoulderof the stud seats on the hub.
Hot Rod
Jun 27, 2008 01:28 AM
Daveloves
Apr 29, 2006 04:32 PM
SkipS
Sep 13, 2005 11:33 PM
ryan
Aug 20, 2005 05:20 PM
Doctor K
Jul 3, 2005 09:22 PM
