Wheels
Old Jun 27, 2008 | 07:11 PM
HBZ_81C3's Avatar
Default Wheels
Has anyone ever installed 10" wide rear wheels? If so were any mods necessary? I am thinking of a set of Billet Specialties Street-Lites 15X8 for the front and 15X10 for the rear. I amwondering ifI can get the 15X10's with 4.5 back spacing to fit. I know the stock backspacing is 4.00" and was interested if anyone has done this.
Old Jun 27, 2008 | 07:55 PM
Dj Envy's Avatar
Default RE: Wheels
Hey, we're interested in nearly the same thing.
I was looking to get 17x8 ralleys for the front and 17x10 for the rear.
For the rear I was looking at maybe 4.5 or 5" backspacing if needed/possible?
Old Jun 27, 2008 | 10:08 PM
pg's Avatar
Default RE: Wheels
I have 15 X 10 on all 4 corners with 255/60/15's in the rear, front tires are 235/70/15 and they fit fine, PG.
[IMG]local://upfiles/2883/3A333B4AB74742C392DF276CFFD3E517.jpg[/IMG]
Old Jun 27, 2008 | 10:35 PM
HBZ_81C3's Avatar
Default RE: Wheels
PG, What back spacing do you have on your 15X10's? Do you run the same offset in front and rear? Thanks for the info.
Old Jun 27, 2008 | 11:00 PM
Default RE: Wheels
With 4" backspacing and 255-60 on mine, I have about 3/8" clearance on the rear tire to the parking brake cable bracket on the trailing arm. No problem on the fronts.
Old Jun 28, 2008 | 12:02 PM
blknblu68's Avatar
Default RE: Wheels
ORIGINAL: pg
Hey PG are you sure those are 15x10`s??
this is a pic of my friends 68 (the green one) with 15x10`s all around with 4 inch BS and i have to say they look way wider than yours??
just wondering as im thinking of going with 15x10 rears on mine but 15x8 up front.
Old Jun 28, 2008 | 12:48 PM
pg's Avatar
Default RE: Wheels
Hi blknblu68, I measured them when I changed the tires, the rims are "Western Wheels" circa 1976.
I agree your friends look wider but he my have a different off set and back spacing since he has flares. I never checked the back spacing on mine since they were already on the car. PG.
[IMG]local://upfiles/2883/E919E6EACF644A1A9ABDB09A9A4FBE82.jpg[/IMG]
Old Jun 28, 2008 | 11:16 PM
Default RE: Wheels
blknblu68: Those are very nice flares on your friend's car. Look very much like the factory flares that the factory put inside the cars w/ a L-88 engine.
Old Jun 28, 2008 | 11:57 PM
Dj Envy's Avatar
Default RE: Wheels
I like the green one. I'm trying to go with wide wheels that will stick out maybe 2 inches from the fender. I think with maybe a shorter offset I could achieve this.
BLEED_BLUE
May 5, 2010 09:42 AM
thetruth
Apr 10, 2008 01:22 PM
