WS wiper question
Relatively new motor, only used occasionalyto see if the wiperswork. Fuse is good. When switched on, nothing happens. I can hear a slight click inside the switch when turned on. Access door doesnot open. Override switch will not open the door either but the headlightdoors will open with that override switch. I can open the wiper doorby going thru the vacuum actuator. Asking for some ideas from some of you gurus out there. Car sits a lot, especially in the winter, but I do start it up now and then.I do not have a trouble shooting manual but will get one if you can't help me here. Thanks, j
Check out http://www.corvette-101.com . I don't have the vacuum operated wiper panel as mine is an '81, butthe sitehas all the trouble shooting info for the head lights, tank and all other vacuum system for the C3. I'd say that you could figure it out with the info there. Good luck.
Check the ground that goes to the bolt on the bellhousing. Should be a large ring terminal and a black wire going to it. Took me a long time to find that on mine. Replaced the switch and found out that was not the problem. Some times that wire gets connected to the starter, not a good move. It often breaks at the ring terminal. Easy fix if that's the issue.
Sorry Alive69, I thought you were having trouble with wiper cover not opening. That is vacuum actuated, no? Thought you were looking for "vacuum and elec." info alike. As for the wiper motor not operating, you'd have to go from the switch to the motor with a multi-meterfollowing the elec. diagram in the manual. I figured that after checking out the vacuum info at that site, you'd beable to isolate the vacuum lines/circuit for the wiper cover. Sure sorry it was all no help.
And
This is exactly one of the problems mine had. Got it working thanks to PG.
ORIGINAL: chvet73
VetteThunder
Sep 30, 2006 02:50 PM
