[Deleted]
Old Oct 15, 2007 | 12:55 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Oct 16, 2007 | 06:45 AM
RudeDog's Avatar
Default RE: Removing the spare tire
Good question....I'm bumping to top of list for answer....
Old Oct 16, 2007 | 07:36 AM
LeesVette's Avatar
I think you can get the spare tire delete package at Ecklers or MidAmerica. Not positive. The spare tire doesn't absorb much of the impact from a rear end crash. It normally just shoves the tire forward, ruining the carrier anyway. It can also snap the bolt the carrier hangs on.
Old Oct 16, 2007 | 07:39 AM
Default [Deleted]
[Deleted by Admins]
Old Oct 16, 2007 | 08:23 AM
LeesVette's Avatar
ORIGINAL: Snow Wolf
ORIGINAL: LeesVette
Do you carry your spare around.
Yes. You should unless your going to use run flat tires and they aren't that good of a tire.
Old Oct 16, 2007 | 08:50 AM
ORIGINAL: Snow Wolf
I am going to remove teh spare tire and the actual carrier. I know theres something to replace it but seems pointless. I am going to clean it up and paint all the parts underneath there to really give it a shine. I know the tank is lined so that helps in a rearend crash but I *heard* that the spare tire takes the impact. True or false? Im going to keep searching but its not very helpful going thru google.
I got mine down right now, only cause I gotta' find out if a missing bushing is causing a light knock sound out back.
Interestingly, two people have asked about rear end ride height bein' high, after seein' some of the car pics in the gallery here. I say it's cause the driveway is downhill, not cause the less weight...
Old Oct 16, 2007 | 08:53 AM
No George - that's 'knock', not n'yuk!
Old Oct 16, 2007 | 10:10 AM
LeesVette's Avatar
That spare tire and carrier doesn't have enough weight to affect the ride height.
Old Oct 16, 2007 | 04:10 PM
ORIGINAL: cwb
OOHHH!...A wiiiizeguy ahhh? [sm=smiley14.gif]
Old Oct 16, 2007 | 09:22 PM
Default [Deleted]
[Deleted by Admins]
