1984 corvette swap
Old May 24, 2015 | 11:51 AM
malinator's Avatar
Default 1984 corvette swap
I was looking into doing a engine swap in an 84. I was wondering if there are any motors that are more or less a direct swap. Or is there companies that sell kits for other motors, like an lsx swap. I'm interesting in doing a swap but don't have the tools or most technical know how to do fabrication work.
Old May 24, 2015 | 07:41 PM
hcbph's Avatar
if you don't have tools or knowledge on how to do it, your best source would be if you can find a kit to accomplish what you want where it includes everything. 2d option would be to hire someone to do it.
Old May 24, 2015 | 09:55 PM
malinator's Avatar
I agree I was looking for some kits. That's why I want to know if theres a direct swap. I meant I don't really have tools for cutting and welding the frame, things lf that nature.
Old May 26, 2015 | 06:36 PM
hcbph's Avatar
You might want to check out Chevrolet.com/Performance. They're boasting you can power an older car with the current LT1 engine, so they may just happen to have kits. Definitely worth a look in your case.
Old Aug 6, 2015 | 11:04 PM
VIN_#_00521__C4's Avatar
Dont do the swap Keep it all-original Rebuild it and Install this Renegade on it
If you are in need of a new a new radiator i have one for sale
This is a Direct-fit Dual Core Crossflow Radiator
W/ Auto Trans Cooler
《Br》
For the 1984 to 1989 C4 Corvette w/ Auto Transmission
《Br》
Dimentions : 28" W x 15" H x 3" D
Core Dimentions : 24" W x15" H x 2" D
Inlet Location : Drivers side
Inlet size 1.38 inches
Outlet location : Passenger side
Transmisssion cooler : YES
Oil Cooler : NO
If you plan to shoe-horn a new motor into your '84 Just remember that the '84 was the ONLY C4 produced with a COLD-AIR INDUCTION HOOD Thats ram- air built into the hood you cut a hole at the front edge of the radiator and seal it with some weatherstripping
thetered
Nov 22, 2007 08:28 PM
JSUTiger
Oct 27, 2006 09:56 AM
supradupraTT
May 10, 2006 01:31 AM
casey38boost
Mar 14, 2006 01:17 PM
MerrionRJ
Aug 4, 2005 02:09 PM
