1995 loose door panels
Old May 31, 2006 | 01:09 AM
grabie's Avatar
Default 1995 loose door panels
I've notice that the top portion of the door panels on both sides are loose so I took it to the local chevy dealer to get them re-attached. They told me that the panels were warped and that the panels have been discontinued on the '95 models and the present ones can't be fixed. For some reason, I still feel that something could be rigged to solve this problem instead of trying to find some after-market brand if one exists. Anyone had this type of problem and if so, how did you fix the problem?
Old May 31, 2006 | 10:54 AM
byedan1's Avatar
Default RE: 1995 loose door panels
ecklers has door panels but i remember reading some where that you can use L brackets from lows and attact them to the door and bend them some and then rehang you door panel and it will hold tight, this is using factory bolts and no drilling i believe two to a door is what you need
94corvette
Jul 7, 2024 10:50 AM
teds64
Jul 17, 2006 11:41 PM
teds64
Jul 3, 2006 04:53 PM
grabie
May 5, 2006 04:22 PM
E.G. 1
Jul 22, 2005 01:30 PM
