84 rebuild gary bakka
when key is turned on it tells starter to engage. purple wire, were are the wires that go to the oil pressure gage, fuel pump relay, fan relay, tried going directly from battery to fan relay and it turns fan on always . have different schematics and none show the correct routing. does power get thru ecm to the oil pressure and then to fuel and fan relays. right now I have it rigged from hot spot on fuse panel to fan relay which engages fuel pump and lets gas flow and engine tries to turn over I get it tries to start but then goes bust. as far as timing it have it at 6 degrees tdc and am turning distributer but to no luck. everything is new in engine. help if u can.
