Primary Cooling Fan Not Working
Old Aug 28, 2007 | 01:56 PM
ru10707's Avatar
Default Primary Cooling Fan Not Working
Hi Everyone. I have just purchased my 2nd Corvette. It is a 1994 C4 Convertable and it has never even been driven in the rain. Now, I am having kind of a strange problem. My Primary Cooling fan is not working, but my Secondary one is. Now, I switched both relays with each other and the secondary fan will work with either relay. Next, I removed my Primary Fan and connected it to a 12 volt battery and it took off like a top. So, I now have put it back on the car and am stumped as to what could be the problem. Also, the Air Conditioner is not working, but I thought maybe just low freon to be the problem. So, consequently, when I turn on the air conditioner, neither fan will run.
Any suggestions would be greatly appreciated
Ru1
Old Aug 28, 2007 | 03:44 PM
rshiver's Avatar
Default RE: Primary Cooling Fan Not Working
Sounds like you may have a bad pressure switch. Does the AC compresser come on? Have you checked the fuse for the AC?
Old Aug 28, 2007 | 04:45 PM
There are 2 fuses on the primary cooling fan. 1 for the load in the underhood fuse panel labeled "Primary Cooling Fan Fuse 2" and 1 that powers relay in the instrument panel fuse block labeled " Fan Fuse". Check both of those. If you have power on both those circuits, then the ECM is not grounding the relay to turn fan on for whatever reason (open circuit, no signal from A/C control, bad ECM, etc.)
Old Aug 28, 2007 | 05:18 PM
rshiver's Avatar
I did read somewhere that someone with 94 Z28 had to disconnect the battery for a few minutes after recharging his AC to get it to come on. Wouldn't hurt anything to try.
Old Aug 28, 2007 | 06:46 PM
ru10707's Avatar
Thanks so much for your help. Do you happen to know where the under the hood fuse box is located?
Thanks
Ru1
oldtvman
Sep 21, 2012 07:29 AM
DryCreamer
May 5, 2008 05:03 PM
anzolv
Apr 6, 2008 11:49 PM
dan33470
Jun 3, 2007 09:19 PM
sciguy6
Jun 3, 2007 08:11 AM
