87 overdrive problems
Old Oct 8, 2007 | 04:15 PM
cole1727's Avatar
Default 87 overdrive problems
Overdrive slips in and out on it's own- Car is new to me....any advice?
Old Oct 8, 2007 | 04:49 PM
Default RE: 87 overdrive problems
Welcome into the forums there, cole...
Fluid is level, I guess?
Does it slip only in O/D?
Old Oct 8, 2007 | 05:18 PM
cole1727's Avatar
Thank you.
Well I just got it - after looking under hood - I can find everything EXCEPT the dipstick for trans. and yes the OD has a mind of its own - it will pop in and out while in any gear -and with that.. it sounds like it's slipping or the clutch is hurting- I was just wondering if anyone had some suggestions prior to me taking it to a dealership......
Old Oct 8, 2007 | 05:22 PM
ORIGINAL: cole1727
Thank you.
OD pops in and out? In ANY gear???
Need a little more detail there, cole...
I highly suggestNO dealer visits just yet. They LOVE to go fishin' for work.
There's a ton of problems thatmight be attributed to bad electrical grounds.
Old Oct 8, 2007 | 05:48 PM
cole1727's Avatar
cwb,its a 87 c4 manual 4 speed but has a 3\4 od. I just got the caranddrove it 2000 miles. sometimes it wouldnt go into od and engine temps would get hot. It now clunks in and out of od unless i gun it. I'm no mechanic and have never had a car like this. i appreciate you helping me.
Old Oct 8, 2007 | 06:23 PM
ORIGINAL: cole1727
Sure!
I don't think temps are related to the tranny problem, although it's always possible. (3/4 O/D means3/4 turn tranny input shaft, 1 whole turn output shaft).
Your tranny's synchronizers might be shot. Not gonna' be cheap to repair either. Don't do anything until you're sure what you've got tho'. Wait for some others here to offer more diagnostic tests first...
It might also be a clutch gig, or throwout (clutch disengagement) bearing. How does the clutch pedal feel? Just a little play before resistance? Does the car pull at all before you let the pedal up to engage the gear?
Old Oct 8, 2007 | 07:00 PM
cole1727's Avatar
cwb,the clutch is nice and tight.1st gear is no problem but once i get into 3rd and 4th it starts clunking in and out of od.I dont even know how to go into od.If i shift it early it seems to help.How much would syncs be? again thanks.
Old Oct 8, 2007 | 07:26 PM
cole1727's Avatar
I have zero experience witha stick with overdrive. Its possible im doing something wrong. Is there a button for od?
Old Oct 8, 2007 | 07:33 PM
ORIGINAL: cole1727
If you got zero problems with 1st or 2nd, your clutch and T/O bearing is probably good.
Synchros might run $425 - $575, if you pull your own tranny. It ain' that hard, you need only workin' space. If they pull the tranny, it might cost $900 - $1100, and the dealer much more.
I highly suggest you find out exactly what is wrong first. Someone here might be able to pin it down, or you might have to see a local - NOT aamco or the dealer. Try to find a fossil runnin' his own place, who's very busy.
Old Oct 8, 2007 | 07:51 PM
rshiver's Avatar
There are several things that can cause a manual transmission to jump out of gear, loose transmission bolts, worn gears, worn synchronizer, worn shift fork, all of these can cause one to jump out of gear.
