96 LT4 1-2 Shift Issue
Old May 23, 2007 | 08:36 PM
mthanson's Avatar
Default 96 LT4 1-2 Shift Issue
My recently acquired 96 LT4 shifts fine from 1-2, when rpms are low to moderate.
At high rpms, when a quick shift is called for the shift to 2nd catches, and makes a slight grinding noise.
I've heard there is a restrictor in the hydraulic clutch feed line that can be drilled out to assist in this issue.
Appreciate any advice from you C-4 LT4 experts.
Thanks,
mth
Old May 24, 2007 | 06:31 AM
Default RE: 96 LT4 1-2 Shift Issue
The grinding you are hearing is due to a worn synchronizer ring in the transmission, especially if it grinds on a quick shift. Not much you can do for it other than disassembly and overhaul time.
mthanson
May 27, 2007 07:47 AM
corvettesrus
Nov 22, 2006 02:06 PM
redvett97
Nov 10, 2006 09:28 PM
vette96
Sep 20, 2006 06:13 AM
airborne
Jul 8, 2005 06:35 PM
