ac compressor leak
Old May 27, 2009 | 05:44 PM
hiramw's Avatar
Default ac compressor leak
have a 92 with the nippondenso compressor. replaced bad seal and changed dryer. need to know correct amount of oil to add to each.did not change to 134a, kept R-12 system. thanks in advance and very glad to join this group.
Old Jun 3, 2009 | 07:13 PM
xfasteddiex's Avatar
i have a 1990 factory gm service manual i know yours is a 92 . but nowhere in the manual could i find anything on how much pag oil to add . but remember unless you evacuatev the entire system the only oil you shuld have lost is what was in the dryer you replaced .oil does not evaporate like freon does . its been a long time since ive done any a/c work but i think a bottle of pag oil is 10 to 16 ounces & thay is all you should need if you need any at all.
Old Jun 4, 2009 | 09:18 PM
If you did not change compressor, you should add about 4oz of oil. Do not use PAG oil if you are still using R12. It should be a mineral oil based refrigerant oil.
drdenny
Aug 14, 2006 02:01 AM
ktrixx
Sep 7, 2005 01:55 AM
GEORGE
Sep 6, 2005 01:24 AM
GEORGE
Sep 5, 2005 10:58 AM
BMWsport
Aug 11, 2005 01:26 PM
