ac compressor leak
have a 92 with the nippondenso compressor. replaced bad seal and changed dryer. need to know correct amount of oil to add to each.did not change to 134a, kept R-12 system. thanks in advance and very glad to join this group.
i have a 1990 factory gm service manual i know yours is a 92 . but nowhere in the manual could i find anything on how much pag oil to add . but remember unless you evacuatev the entire system the only oil you shuld have lost is what was in the dryer you replaced .oil does not evaporate like freon does . its been a long time since ive done any a/c work but i think a bottle of pag oil is 10 to 16 ounces & thay is all you should need if you need any at all.
