Brakes Grind
Old Aug 29, 2007 | 01:36 AM
mraaron895's Avatar
Default Brakes Grind
I have an 86 with a brake issue. Not all the time but alotof the time when i apply the brakes at in-town speeds to come to a stop my brakes seem to grind and slip. They make a very disturbing noise like metal grinding on metal. I took it in to les schwab and they said my breaks and rotors were fine. Anyone know what my problem is?
Old Aug 29, 2007 | 06:02 AM
RudeDog's Avatar
Default RE: Brakes Grind
Man that sure doesn't sound like they are fine. Especially the grinding sound. Could dmg your rotors
and that is $$$$$$. You could have a build up of brake dust. Is there dark residue mounting up inside
your wheels?
I recently had the squeeking problem. Had ceramic pads installed on front. Problem cured. Good luck.
Old Aug 29, 2007 | 09:44 AM
LeesVette's Avatar
The problem is you took it to Les Schwab.
Old Aug 30, 2007 | 09:05 PM
gizwilly's Avatar
Where are ya?
I'm in Albany. If you'd like to meet I'll listen to your prob and you can listen to mine.
Who knows? We might solve 'em!
Old Aug 31, 2007 | 03:50 AM
mraaron895's Avatar
Well i took it down to the wishy washy and pressure washed the inside of the wheels. It seems to work allittle better. cause there is alot of tough road grime covering everything. i'll try blasting it again and see if that cures the problem. would buying some disc break cleaner be a good idea?
Old Aug 31, 2007 | 07:41 AM
RudeDog's Avatar
I had considered that as a temporary fix but on most of the cleaners you have to take the wheels
off and I don't have the facilities at home for that. There may be a spray with wheels on but it's
usually too windy here in Paducah for that and I don't want to clean up a mess on my garage floor.
The "wishy-washy" spray may be the best temp. fix but if you need pads I definitely reccommend
ceramic.
Old Aug 31, 2007 | 11:52 AM
Eggster's Avatar
ORIGINAL: LeesVette
I've had very positive experiences with their service.
@Mr. Aaron: You may want to remove the wheels and check to see if any pebbles or debris has gotten stuck in the brake pad itself. It's worth checking.....
Old Sep 1, 2007 | 02:45 PM
9340Vette's Avatar
Did you ever figure out the brake problem? BK
Old Sep 1, 2007 | 04:59 PM
mraaron895's Avatar
I will be taking off the wheels this monday. I've done it before when i rotated my own tires. I'll let you guys know how it goes. Thanks for the replies!
lucid
Jun 4, 2022 03:48 AM
Eagle223usa
Sep 1, 2005 12:12 PM
tonyb
Aug 28, 2005 09:48 AM
crausch
Jun 28, 2005 03:51 AM
71LT1
May 31, 2005 12:51 AM
