C4 Radio Won't Stay on AM/FM
Old Apr 17, 2022 | 09:25 PM
brennan626's Avatar
Default C4 Radio Won't Stay on AM/FM
I just bought my first Corvette: a 95. It has a problem with the radio though. It has the Bose Gold system. When you turn the radio on, it defaults to CA/CD move. I can change it to AM/FM but it will only stay on it for about three seconds before kicking back to CA/CD. I have checked and there is no cassette or CD in the radio. I was wondering if this was something anyone else has experienced or if my radio is just kaput. The power antenna works well, meanwhile. I just wish I could utilize it and listen to FM.
Old Apr 18, 2022 | 03:23 PM
Welcome to the forum. The only thing I could suggest would be to pull the fuse for the radio for a couple of minutes and put it back in to see if that has any effect.
Old Apr 18, 2022 | 04:26 PM
KTM rdr's Avatar
Does the CD select button feel normal? Could be the tact switch behind the button is bad or just stuck. You have to pull the head unit to check, might just need cleaned. Beyond that it's probably a fault in the head unit. There are services that will repair or exchange if you want to keep it original.
Old Jun 6, 2022 | 08:36 AM
brennan626's Avatar
I figured out what it was! There was a tape jammed up inside the tape player. I had to take the radio out and take it apart to get it out, but now it works fine.
Old Jun 6, 2022 | 08:39 PM
KTM rdr's Avatar
Good job. Thanks for letting us know the solution.
QuickNick
Nov 13, 2022 10:09 PM
Alans 94 vette
Jul 4, 2022 10:22 AM
dale
Jan 24, 2008 09:27 PM
deansreef
Mar 23, 2007 11:56 PM
