Cast Iron or Aluminum Head in my 1986 convertible?
Old Jun 13, 2006 | 01:43 AM
chase sperry's Avatar
Default Cast Iron or Aluminum Head in my 1986 convertible?
I have a 1986 convertible and am trying to figure out if it has a cast iron or aluminum head from the factory. Anybody know?
Old Jun 13, 2006 | 09:35 AM
Default RE: Cast Iron or Aluminum Head in my 1986 convertible?
Aluminum heads have center bolt valve covers, steel heads have perimeter bolts on the valve covers.
Old Jun 14, 2006 | 02:27 AM
Ill have to check it out. Hopefully aluminum so i can get that whopping 5 hp extra!!!
Old Jun 14, 2006 | 02:48 AM
raisinbran's Avatar
I believe all verts in 86 had aluminum heads. Take a magnet and see if it is pulled to the heads.
Old Jun 14, 2006 | 09:16 AM
Not true on all 86's. Mine is an 86 and it has steel heads.
Old Jun 14, 2006 | 02:49 PM
Magnet will stick if it is cast iron right?
Old Jun 15, 2006 | 12:57 AM
Yes, but the dead giveaway is the valve cover bolts. Center or rim?
Old Jun 15, 2006 | 02:17 AM
Ill look tomorrow, its at a friends shop
Old Nov 22, 2006 | 01:21 PM
JoeVetteman's Avatar
It depends.I believe the '86 had iron heads until February of '86.Check your tag on the inside of the driver's door.You should be able to tell.Good luck.
Old Nov 22, 2006 | 01:58 PM
Black86vette's Avatar
umm. Yea I saw this and checked mine. My car was made in november 1986 because I have the removable top and I took the felt off of it inside because its not a clear top and it said it was made in 11/18/86. I changed out valve covers but they are on the corners of the valve cover and the spark plugs I install are for cast iron. Why if my vettes a late 86 I guess have cast ironn? Will my VIN number help you guys help me figure out whats up?
